theyyampattil
Grain details are not getting in csv file
in sketchup open cutlist while exporting into csv file we could not get data regarding grain orientation column
The grain property is not defined per part, but at the material level. If a material has a grain, it is always oriented along the length dimension (even if that dimension does not correspond to the longest dimension).
So there no column because it's the same value for each part : grain is always along the length.
theyyampattil
to bring a column of data representing grain,is there any solution?
What this column should contain ?
theyyampattil
this column should contain grain orientation details like if length follow grains it may be show value 1 or 0 and vice versa
So you can use the grained? property on the material variable type.
87 vues
