mightyg
What is causing "No Material found"?
Hi,
I'm new to opencutlist and love it, however on my first model I have a problem. I have made materials for MDF, but for some of them it says "No Thickness defined", but if I click the "add thickness" button, nothing happens.
Then if i edit the material and type in the thickness (in this case 12mm) it comes up with the message "No Material found"
can someone help ? Many thanks
Paul
Strange problem. Could you please send some screenshot of your problem ?
thibault81
Hi Paul, make sure you select all your panels in sketchup, they all should be component and overligned in blue before editing your flow sheet. If not, it won't work.
I'm not sure if i understand clearly your problem thought, but it rings a bell from when i started to use it.
Good luck, and yes, open cut list is wonderfull.
mightyg
Hi, i've attached a screenshot, what I am finding if i try and make mdoifications to some of the materials it says "no material found", i've tried various solutions but still there is the problem
mightyg
I thought i'd found the solution by making a new material, but this doesn't seem to be working now
Could you try to remove the « + » from material name ?
mightyg
It worked !! Thank you very much Boris - that is such a relief :-)
Paul
mightyg
Hello Boris / thibault,
I read more of the forum questions and found one which was similar. I think the issue is caused by using another material as a template, and if it doesn't have the thicknesses defined then you cannot add them. I have since made fresh materials to do the same thing and it seems to work.
It would be good if the issue didn't exist, but at least there is a workaround :-)
thanks
Paul
What is your version of OpenCutList ?
And could you send a sample of your problem to opencutlist@lairdubois.fr ?
388 vues
